Hosts use the Internet Group Management Protocol (IGMP) to report their IP multicast group memberships to neighboring multicast routers. Configure IGMP on an individual interface basis.
Important
Important
The EnableSpbmConfigMode boot flag must be disabled before you can configure PIM or IGMP. To verify the configuration, navigate to Configuration > Edit > Chassis and select on the Boot Config tab.
  • Configure IGMP on a Layer 2 interface by enabling IGMP snoop.
  • Configure IGMP on a Layer 3 interface by enabling multicast routing, for example, Protocol Independent Multicast-Sparse Mode (PIM-SM), or Protocol Independent Multicast-Source Specific Multicast (PIM-SSM).
Important
Important
To configure and use IGMP on a VRF instance you must first select and launch the VRF context.
To select and launch the VRF context, see Select and Launch a VRF Context View.
